White cleaner tip replacement
  • White cleaner tip replacement
    Noticed the white cleaner tip where the blue one screws into is leaking. Just wondering on the procedure to replace it. Basically it goes: Blue screw on tip, white plastic tip, metal tube...Just wondering how to push the tube through the metal tube so I can change it. Seems like something is holding it in.
    I assume that you have checked that the actual blue tip is not the issue
    I think you replace the entire tube and metal stem as an assembly
      You can replaced the white louvre only. It's been a while since I've done one. You need to pull the tubing out past the metal tube. Then insert the white louvre into the tubing. Then carefully press the tubing into the metal tube until the louvre touches the metal tube. I don't recall any glue being used to hold the louvre in place.
      Cloth: ShamWow!
      Machine: Johnny 5
