kp computer issue
  • kp computer issue
    OK the oil head relay in my kp's main computer is going out. I was told that it is relay #10 in the computer. I was just wondering if anyone know the omron part number for that relay so I can try to have it repaired locally instead of having to send it to omrons repair center or have to install a new computer. I really don't want to pull that computer apart unless I have to.
    I cant remember exactly right now but relay 10 maybe one of the white relays in the green christmas tree stack off to the right side of the computer. If so just the white relay can be swapped without buying the green part too for dirt cheap,trade the relay with a different one on the machine and see if the issue moves.
    70's MP/PBL/LBS,Q-Score
    Prolane Walker sport
      Is this what you are looking for?
        The internal relays are soldered on the board, so unless you know how to do that, you could be opening a big ole can o' worms. As the others have stated, try the external relays first if you haven't already.
        Cloth: ShamWow!
        Machine: Johnny 5
          I've already tried every external relay in the machine. I know for a fact its in the main computer -_-. And I was told that I could get a computer repair shop to replace the relay. I just need to order it first. I already have the new computer for the machine. But I can't send the computer back if I use it. And I would really like to avoid putting it in.
