I forgot to look and see which version thoughtware we have, and I can get that if you need it, but anyway I'm having an odd problem. Our PXS-C has 7 program slots. Maybe once a week, when I go into the oil volume test, it says PROGRAM 8. You can use the arrows to scroll all the way up to 99, and if you select one of these, it will run an oil program (program 49, for instance, puts out approximately 17mL of oil). However, if you exit out of the test screen and MENU through til you get back to it again, it will come up with PROGRAM 7, and you're able to select between programs 1-7.
On its own, this isn't a problem. I never use this feature anyway, I always use the second option, volume per board test. When you go to override the program, I can't ever go above 7. All I know is there are programs 8-99 in the test menu, and they Is this indicative of another problem that needs attention, or should I look away, plug my ears, and go "lalalalalala". Our budget dictates I do the second thing.
