KOSI not saving settings
  • KOSI not saving settings
    Hello, I recently purchased a sanction standard elite machine and downloaded KOSI. Went through the setup and set my thoughtware to SE908 for the Sanction machine. Clicked Ok. Machine wouldn’t connect, so checked the settings and it was on thoughtware S3002 which is the default. I changed it again and clicked ok. Didn’t update. Tried changing to a different machine option and thoughtware and it did save it. But for some reason it will not save it for my machine and thoughtware. It always goes back to default...any ideas or suggestions?
    What version of KOSI do you have? The latest is Version 7.4.3.8 Also make sure the correct port is selected.
    let me be myself
      Thanks for responding! Yes that is the version I have. I just downloaded and installed it last week. I also, deleted it and reinstalled and still not saving the settings.
      Streamlane Mask Halo Lights
      Baddest Tool Chest In Town
      Adios, motor boater!
      Aluminum Repair and Welding
      http://aluminumrepair.com/...
      Hi, guys.
      check this jam...
      the ball stuck the table up
