pattern for lane walker
  • pattern for lane walker
    i can't get any pre programed patterns to work well in my walker.
    Ive got 10 yr old bruns anvilane. currently using prodigy (50 mic). defence-c 6 to 1. i am looking for a easy house shot.
    Re: pattern for lane walker
    Here is a pattern we have been running on Heddon synthetics, <15 yrs old>, prodigy @45 mic stream, w fizzion mixed 6 to 1. Should get you close then you can always tweak them.
    39 ft.
    2-2-2-10
    7-7-1-10
    9-9-1-14
    10-10-3-18
    11-11-2-22
    12-12-2-22
    2-2-0-22-33ft
    2-2-0-26-39ft.
    Rev to 29 ft @ 30
    14-14-2-22
    12-12-2-18
    11-11-2-18
    10-10-3-14
    9-9-1-14
    2-2-0-14
    Not really sure how your surface would play compared to ours, but this pattern is really quite easy to get to the pocket with.
    I got it fixed--too bad it wasn't what I was trying to fix.
      The Heddon surface should play pretty similar to the Anvilane surface. Though 39' sounds a little short the rest looks pretty good.
      Cloth: ShamWow!
      Machine: Johnny 5
        Not for SC.....he needs all the back end reaction he can get.
          So I take it SC has a 500 rev rate...10 revs down the lane and 490 on the way back?
          Cloth: ShamWow!
          Machine: Johnny 5
            10 on the way down might be too many.
            8 on the way down....2 on the pit board.....490 on the way back.
              alex or king would you recommend any tweaks to this pattern.
              am i using the right oil for this surface ?
                40 ft.
                2-2-2-10
                7-7-1-10
                9-9-2-14
                10-10-3-18
                11-11-2-22
                12-12-1-22
                2-2-0-22-33ft
                2-2-0-26-40ft.
                Rev to 29 ft @ 30
                12-12-2-18
                11-11-2-18
                10-10-3-14
                9-9-2-14
                8-8 1 14
                2-2-0-14
                  I think that Navigate, Infinity, or Lubricity may be better suited for your surface. Open play vs league play is a factor as well. But Prodigy, in my opinion, is a little too hooky for the Heddon surface. I'll second Jerrys tweak.
                  Cloth: ShamWow!
                  Machine: Johnny 5
                    King--you should see me now!! 500 revs would be a 'low' estimate now. I am getting all over it now--only in my dreams. 39 ft. seems to be sufficient on my surface b/c scores are really good. I do understand that not everyone can use the same pattern, I was just getting them started.
                      hey thanks king.I've ran this shot for the last three weeks and i my bowlers love it. (3 300'3 2 800's and many 275+ games) a few are complaining that there is not enough back end, but even they say the shot is better. i am still seeing some carry down but not as bad. i am getting a sample of infinity and will post back after switching. will i have to make any changes to the program or the machine when i switch oil's? thanks again
                        39 feet...you have the lane machine set on full knuckle...
                          Full knuckle? LOL that is pretty good!!!
                          Baddest Tool Chest In Town
                          Adios, motor boater!
                          check this jam...
                          the ball stuck the table up
