logic on 3-4 yr. old spl
  • logic on 3-4 yr. old spl
    Does anyone out there have a program that is working well ? Ive been transitioning from utopia and its been tough. Just want to see if I am way off base. Thanks in advance if you can help
    Post you pattern and tell me the issues with how it plays
      Been using what you suggested with tweaks. been backing off for 4+ weeks. Middles seem slippery and everyone moves right and they dry up. Not wide open/ lesser guys are struggeling, wet early then dry up. Just want to know if I'm way off what it should be.
      2-2-2-14
      7-7-1-14
      9-9-2-14
      10-10-3-18
      11-11-2-22
      12-12-1-22
      ---------22-34
      ----------26-40
      ----------26-34
      13-13-1-22
      12-12-1-22
      11-11-2-18
      10-10-3-18
      9-9-2-18
      8-8-1-14
      ------14 -0'
        Here is my pattern. Just switched to logic about 6 weeks ago and since switching league averages have gone up about 8-10 pins in each league. I have a sanction standard Elite Machine on 10 Year Anvilane Lanes. Using Logic and Max 10 Cleaner.
        40 Mic Stream
        2-2-2-10
        7-7-1-10
        9-9-2-14
        10-10-2-14
        11-11-4-18
        13-13-2-18
        ---------18-28Ft
        ---------22-40Ft 11.8 mL Fwd
        ---------30-34Ft Reverse Buffer Drop @ 34 Ft
        14-14-2-18
        13-13-1-18
        12-12-2-18
        11-11-2-18
        11-11-2-14
        10-10-2-10
        9-9-1-10
        ------10-0' 8.64 mL Rev
        20.44 mL Total
          Try the above pattern!
            haus lane man do you have the brush upgrade? I don't
              Yes that pattern is used with the one piece buffer brush with reverse buffer drop software
                I went back to Kegel on my SPL's as I just couldn't get any consistency with any other oil. The Logic works great on my Pro lanes though.
                Drill
                David Bolt
                Champaign, IL
                USBC Silver Coach
                IBPSIA BOD
                IBPSIA Advanced
                Technical Certified
                Pro Shops
                  I should say smoothing blocks or brush ?
                    Drill, what oil ? What did logic do on yours? How long have you had yours? Mine 1st yr. great/utopia 2nd slippery and dry up 3rd terrible utopia supposidly changed I don't know. Tried logic because of good reviews.
                      Used haus's pattern for two nights (I worked last night / bowled tonight) not bad but hooky. track and out side guys had to throw fffaaasssttt.when it hooks like a basterd the carry interesting.
                        King, the league ave. was up 5 pins over the last two or three weeks. It was real hooky outside 2nd until the transition 6th or 7th frame. 3rd game really went away. How would you soften it up alittle at the start and is there a way to not run 10 speed on rev. I run lanes between 4pm and 6:45 shifts and time is tight.
                          7-7-1-10
                          9-9-2-14
                          10-10-3-14
                          11-11-3-18
                          13-13-2-18
                          ---------18-28Ft
                          13-13-1-18
                          12-12-2-18
                          11-11-2-18
                          11-11-2-14
                          10-10-2-14
                          9-9-2-10
                          8-8-1-10
                          20.44 mL Total
                            The numbers on Kings tweek are not coming out . Can you check what's wrong with it?
                              what's not right? This old math with a Standard se with smoothing blocks.
                              Blue A2 Rebuild
                              Here are photos of the A2 that I just finished rebuilding and installing. Every single part on the machine came apart to be cleaned, painted, or replaced. All new rubber,...
                              Streamlane Mask Halo Lights
                              Hybrid (and EcoFriendly) Bumpers (2012)
                              It's been about 10 years since we first tried this - 46 lanes and still working fine, auto air bumper cylinders on the BankShot bumpers. Here are videos of a home install with...
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
