need house pattern for summit
  • need house pattern for summit
    i need an easy house pattern for one of the houses that i oversee.the machine there is a yellow summit.not sure on the exact name of the machine.using brunswick control lv oil and st-21 ultimate stripper.any help would be great.if you need any more info on the machine let me know and i will get it.
    hey just because its used doesnt mean its no good.
    got some more info. its a summit s-series machine. the house has wood lanes.high flow wicks.
      Any idea on current pattern and how they play?
        from what ive been told it plays like a 10 to 10 shot.the lenght is 39 ft.i did bowl on them a while back and they hooked had to get in around 3rd arrow.personally i just want to start fresh
          Did you get my PM?
            yes i did i tried to email you but no luck. i responded to your pm with my email address. thanks
