After some advice/reassurance on a pattern?
  • After some advice/reassurance on a pattern?
    Hi again, after being able to help out with the pattern I questioned about earlier in the week I was wondering if you would be able to give me some advice?
    I was just wondering if you feel that the pattern below would hold up well enough for a 4 man team league night (3games) if not what changes could you recommend without changing the ratios too much.
    40ul
    Forward:
    2-2 4 14
    6-6 4 14
    10-10 2 14
    11-11 1 14
    14-14 2 22
    14-14 3 22
    2-2 0 22 42'
    Reverse:
    2-2 0 10 33'
    14-14 2 18
    14-14 2 18
    14-14 1 22
    2-2 0 22
    Ratios at present: Middle:middle track - 2.19
    Middleutside track - 3.75
    Thanks for taking a look
    7-7 1 14
    9-9 2 14
    10-10 4 14
    11-11 4 18
    12-12 3 18
    2-2 0 22 33-41'
    2-2 0 30 41-30'
    12-12 3 22
    10-10 3 18
    8-8 1 18
    2-2 0 18 8-0
    40mic stream
    20.88ml volume
      Thanks king
      I'm just trying to get a small library of patterns together for a monthly tournament that we run at our bowl, will have a practice on this pattern and if we use it i will post how it got on.
      Thanks again
