King, this started as a brush to brush pattern but I tried it anyway,It's better than what I had. But with a tranfer roller the outsides are really dry, If I speed up the mach. then the middle is too far and the break point is wrong. How can I get allitle more outside without changing the middle? thanks!
I'm definitely not the king but I would remove a 13-13 forward and add an 8-8 forward. This will assist with the over/under without changing anything in the middle.
1. When you run the 1st two screens slow in the forward run you are dumping all the track oil at the foul line and first few feet
2. When you speed up the buff screens you are getting the oil down the lane and making the over under
King, one night in 1 300 and 1 299 It had good hook in and out. (we had 38 degrees and damp out) so I'll need to see it over a couple weeks. This only has 6-7 ml on the return, I see you are trying to go with mostly forward oil. What is the reasoning? New oils/tranfer roller/smooth surfaces? are the new balls made to blend the wet dry better? (seeing it's 90% of what we're bowling on)
King, correction on what I said the other day.The 12-12-2 forward I made 13-13-2 because the pattern was close to something I ran a couple months ago when the inside guys got pushed over to the straight guys causing burn up. Thurs. was one of the first times that the curvers could play in and the staight guys could play the normal track. I totally agree with some of the comments about the fact that you don't need a ton of oil to have great score. Spread people out and you will get longevity!
When the lanes are slippery in the middle and the ball will hang, then you move alittle right (dry outside) and the ball will hook through the face. You go 2,4,5,8,bucket to the 3,6,10 and you moved a board or two. The newer balls seem to accent this reaction.
King, monthly update, still running the pattern with the 13-13's instead of the 12-12. Just as before hit and miss but I left it alone.I did put in some old amflites two weeks ago and it made a huge difference. One month, 8-800's , 11-300's , 9-299's , 1-298 ,and 1-297. This did include a one day city tourn. and our city kids traveling league.
