I havent change anything in the machine or pattern, and then all of a sudden the back-ends are almost wimpy......The only thing different is I opened a new box of oil.......King have you heard anything or anyone else say anything about OffensLV getting weird on them. My pattern reads the same, but something just isnt right.
back ends have got weak
Well.....my first guess is that open bowling is busy....and even one day of huge open play will get much more carry down on the backend
Unless you strip twice a day....your cleaner mix should be 4-1 to get the lanes clean with all the extra winter traffic
You cannot clean with weak solution when busy....think about it...we all build our pattern in the fall when not busy....then it gets tighter with the weather and all the carry down
