Problems
  • Problems
    Having way too many 300's & 800's, averages are up in the 230+ range and carry is just out the roof, what do I do????
    Drill
    David Bolt
    Champaign, IL
    USBC Silver Coach
    IBPSIA BOD
    IBPSIA Advanced
    Technical Certified
    Pro Shops
    Smile.
    Every Man Must Think Something, So I'll Think I Will Have Another Drink. W.C. Fields
      Hahahaha
        Get rid of those crappy synthetics and put down some guardian..problem solved.
          All you have to do is be happy because maybe you are getting a little less grief from the whinney bowlers this season! lol
          Nick
            I would put some oil on your pins, I here that HELPS!
              hahaha! yeah, oil on pins will surely help you high scores "problem" lol
              Nick
                And your holy grail looks like...
                  Drill, Is that at both places or one better than the other? What programs? Still Logiic-prolane and prodigy-SPL ?
                    Yep, Logic on Pro Lanes & Prodigy on SPL's with the guidance of Jerry on what pattern to put down.
                    Drill
                    David Bolt
                    Champaign, IL
                    USBC Silver Coach
                    IBPSIA BOD
                    IBPSIA Advanced
                    Technical Certified
                    Pro Shops
                      Awww...shucks
                        Drill, smile and enjoy the sound of the registers ringing away!! Are you having the mens state tourney again any time soon?
                        Gene Simmons for president!!!
                          Senior State this coming fall and Men's state the following spring, another very busy year, life is good!!!
                          Drill
                          David Bolt
                          Champaign, IL
                          USBC Silver Coach
                          IBPSIA BOD
                          IBPSIA Advanced
                          Technical Certified
                          Pro Shops
                            Drill, I know what you mean, we have had 37 honor counts in the first two months this year along with a National sport record. I am pulling my hair out!
                            Television is called a medium because it is neither rare or well done.
                              Drillman, this can't be so. I suspect the bowlers are getting away with changing their scores. You are going to have to put your foot down, and disable those keyboards.
                              Now, the savy proprietor will be charging a premium for high scores. Individual bowlers with over 210 average have to pay x$ since they certainly don't need all those extra pins.
                              If that sounded like our president, it was meant to.
