Changing machines, need a pattern
  • Changing machines, need a pattern
    Switching soon from a phoenix B machine to a Sanction standard AC. I'm looking to start fresh with a new pattern. we usually use a shot for seniors, a shot for the men, and our normal house shot. What I want is just one shot. This 3 shot thing is ridiculous.
    As of right now its using the smoothing blocks on the transfer roller, im going to do my best to upgrade to a transfer brush but not until next season is about to start. So sometime in august. But what i need now is a place to start with for the summer leagues. We have HPL heads and wood back ends. Right now our shot is 44' and seems to be decent. I would like to try and keep it at or below 20ml of oil without having an uncontrollable back end. Anything more and i start having problems with my kickers.
    50 mic stream
    44'
    20.2 volume
    2-2 2 18
    8-8 1 18
    9-9 2 18
    11-11 3 18
    12-12 2 18
    2-2 0 22 22- 44
    2-2 0 30 44-32
    12-12 2 22
    10-10 3 18
    9-9 2 18
    8-8 1 18
    2-2 0 18 10-0
      Thanks. Ill try it out and bowl on it this afternoon and let you know how it works
        Welcome
          k i bowled on it a bit. best place to play is around 15-17 but if i try to play over 10 out to about 7-8 the ball seems to hit a wall in the middle of the lane and without adding speed it goes through the nose every time. And forget down and in, brooklyn every time. The distance seems to be good and the back end is very playable, its just that dry area as you get outside of ten in the middle of the lane that makes it difficult because the ball slides, grabs, slides, then grabs again at the back end
            50 mic stream
            44'
            2-2 2 18
            7-7 1 18
            8-8 2 18
            11-11 3 18
            12-12 2 18
            2-2 0 22 22- 44
            2-2 0 30 44-32
            12-12 2 22
            10-10 3 18
            8-8 2 18
            7-7 1 18
            2-2 0 18 10-0
              What oil your using would be go info too.
              Cloth: ShamWow!
              Machine: Johnny 5
                Sorry. Prodigy oil, oxyshock cleaner. I have a weird ball return issue that really took over my day yesterday so i havent had a chance to try out the modified pattern. but i will soon
