Michigan State Masters shot.
  • Michigan State Masters shot.
    Don't know if I'm allow to post a direct link or not, but here is the shot..
    http://mistatebowl.com/masters/2012%...%20pattern.pdf
    Graph at
    http://mistatebowl.com/masters/2012%...rs%20graph.pdf
    Lane Surface is Brunswick Pro Anvilane
    41 ft. pattern sheet lists 80 ul per board???
    Forward
    2 2 4 10
    3 3 1 14
    5 5 1 14
    10 10 1 18
    14 14 1 18
    2 2 0 18 11 ft - 41 ft
    Reverse
    2 2 0 30 41 ft - 20 ft
    12 12 1 18
    7 7 1 18
    3 3 1 14
    2 2 0 14 15 ft - 0ft
    My questions basically are... 1) What type of machine is this possibly for (a transfer roller?).. with the 80 mics per board? 2) Can this be duplicated on a Kustodian plus? 3) How might the pattern play and what equipment would be best suited for this pattern? 4) I have never seen anything over a 50 mic pattern. Is this 80 mic common?
    Thank you,
    Joe
    My center 300 bowl is hosting this tournament and we put the shot out to practice on ever mon, wen, thurs, fri and sun.
    Surface is pro anvil machine is Phoenix/s xfer roller @ 80micros. no it's not common.
    I've had very good luck with my house shot running at 80
    and rather then mess with the pump i decided to just keep it there.
    Tim
      Wow.....the ball will hook from 10....and will not hook right of 10....start inside.....and keep moving left as they burn up
        Witch sounds like every other sport condition put out by USBC.
        Also note the oil is legends 62vic so king is right they will burn up
        Tim
          Thanks for the input guys.
