Kustodian Buffer Dripping Oil
  • Kustodian Buffer Dripping Oil
    When I changed from 40 to 50 output machine started dripping oil badly from buffer bruch when left on approach for a while. How can I correct this problem so that I can run 50 output patterns?
    Is it coming off the brush or the felt on the splash gaurd side?
    Why yes, we wax them everyday!
      Dripping from both locations.
        I'm sure you have checked for leaks, do you think it could be your pattern, you may be putting out too much oil in the heads on reverse pass and not burning it off causing overloaded buffer to drip when setting for a long time, when you go to 50 you are putting out 20% more oil. Usually if this is the case the lanes will get tighter the more lanes you oil.
          Also check to make sure the pencil tip is still at the end of the tubing in the oil head.
          Pete
            Interesting. I've had the same problem after making the same change to my pattern. Didn't think that would have an effect. Any insight provided would be very helpful to more than one mechanic!
            GSX Noob
