2012 PBAX Pattern
  • 2012 PBAX Pattern
    My Opinion:
    1. DO NOT RUN THEM AS THEY ARE GIVEN TO YOU
    2. Adjust the speeds in the PBAX patterns to be like a normal pattern
    3. You run the risk of catastrophic gearbox failure if you do not run the patterns as the Kegel manual states
    You are to build patterns that gradually accelerate in the forward pass and gradually decelerate in the reverse pass
    I agree. the speeds on the Shark pattern are odd. I haven't really look at the rest.
    Cloth: ShamWow!
    Machine: Johnny 5
      I do not think they are odd - they are destructive
        I say odd because I'm curious about the theory behind it. But I would not run the pattern as posted. Besides stock patterns play different in every center so it's not like anyone would know the difference. minus the speeds it looks like it would be fun to bowl on.
        Cloth: ShamWow!
        Machine: Johnny 5
          It is comical that some of the patterns have small areas of oil patches in them
            Remember Sanction Technology can't oil in zones like the A22/Envoy that is used on tour. I'm guessing some one with the PBA came up with the Kegel conversion since they would need them for the regional tour. Since the PBA did away with the regional Lanemen, it's up to the center to use their own equipment.
            Cloth: ShamWow!
            Machine: Johnny 5
              Originally posted by 8270king View Post
              My Opinion:
              Question, By adjusting the speeds will the patterns still retain the ratios? (3 to 1)
              Every Man Must Think Something, So I'll Think I Will Have Another Drink. W.C. Fields
                They should
