i want a ditch
  • i want a ditch
    hey guys i want a pattern that is really easy i have a kegel kustodian plus with a transfer brush, use prodigy oil and fizzion tablets the lane surface is wood, Just wondering if someone could help me
    41 feet
    50 mic stream
    20.55 total volume
    2-2 2 14
    8-8 1 14
    10-10 3 14
    11-11 2 18
    12-12 3 18
    2-2 0 22 22-41
    2-2 0 30 41-31
    13-13 2 22
    11-11 3 18
    9-9 2 18
    7-7 1 18
    2-2 0 18 9-0
      king,
      what do you think of using this pattern on old anvil with 40 mic?
        Try it!
          starts out great, but gets wet/dry pretty fast. can't move in and get the ball to turn the corner. shorten to 41?
            8-8 2 14
            10-10 3 14
            11-11 2 18
            12-12 2 18
            2-2 0 22 22-41
            2-2 0 30 41-31
            13-13 2 22
            11-11 3 18
            9-9 2 18
            7-7 1 18
            2-2 0 18 9-0
            Does your machine have reverse buffer drop
            If not you need it
            I would change to the above pattern and switch the distance back to 41'
              Sorry. I did not run the above. Ran Stone street, which needs the slight tweek. same idea? add 1 on the first load froward, and subtract 1 on the lastload forward?
                Run the above pattern at 41 feet
                2-2 1 14
                9-9 1 14
                The above is too narrow narrow and will burn up immediately
                Running it at 40 mic is fine
                41 feet is good if it will not make the corner
                  9-9 1 14
                  10-10 3 14
                  11-11 2 18
                  12-12 3 18
                  2-2 0 22 22-41
                  2-2 0 30 41-31
                  13-13 2 22
                  11-11 3 18
                  9-9 2 18
                  7-7 1 18
                  2-2 0 18 9-0
                  Run this King?
                  The Stone street from kegels website has been unbelievable for straight and hook players. Tweeners are struggling a bit getting caught in between.
                    No
                    I said run this pattern I posted above
                    Run this pattern I just posted
                    And you can run it 40 mic
                    2-2 2 14
                    8-8 2 14
                    10-10 3 14
                    11-11 2 18
                    12-12 2 18
                    2-2 0 22 22-41
                    2-2 0 30 41-31
                    13-13 2 22
                    11-11 3 18
                    9-9 2 18
                    7-7 1 18
                    2-2 0 18 9-0
