Pattern Tweek
  • Pattern Tweek
    Need a little less at end of pattern
    Cleaning good
    50mic
    40ft
    rbd37ft
    2-2-14
    8-1-14
    9-1-14
    10-3-18
    11-2-18
    12-2-18
    2-0-22-40
    30
    13-2-22
    12-3-18
    11-3-14
    2-0-14-0
    19.75 total
    Kustodian/C RBD Spray time on 4/ distance 24
    Max 20 Cleaner Infinity Oil
    40ft
    rbd34ft
    2-2-14
    8-1-14
    9-1-14
    10-3-14
    11-2-18
    12-2-18
    2-0-22-40
    2-2 0 30 40-31'
    13-2-22
    12-3-18
    11-3-14
    2-0-11-0
    19.75 total
    I changed the speed of you 10-10 loads going forward....this will allow better taper....
    I also changed where your reverse loads started...they were at 34'....I brought that back to 31'....and changed the RBD from 37-34'
    Let me know how it plays!
      Ill put it our for a week or so and let you know
      thanks
        Shot is playing better already. I had corner pin problems but now with the slower speed and the shorter rbd balls are
        turning the corner a lot better. I did however add a foot (41) for higher rev bowlers. I'll leave it out and let you know
        how it continues to play.
        thanks
          Great!
