Enlightnement from the King!
  • Enlightnement from the King!
    Ok Jerry, I've been out of the biz for 10 years now and want to know what MIC is - are centers all metric now on oil per board?? - I remember Milliliters per board or Mils per foot per board. I'm just asking as I'm thinking about hosting/producing a 1970's era tournament where I can set the machine, or spray a pattern by hand- which I can do!! with bowlers only allowed to use plastic - aka blue/white/yellow dot balls - per what I grew up on - I believe it will be a rude awakening to the young kids - I'd probably run 3-6 to 3-10 pins also, but do not know the minimum limit now!! - You are the guru Jerry and I need some wisdom since I'm catching up with you in years!! I still have all my digits on both hands after 20 years on 70SS machines - I gave it up after working with too many brain dead management types!! I hope you are fine and well - you have helped me out on a few occasions I remember and I hope to have helped you just the same!! - I had to get out of the biz or end up dead - but - I found something to get me by - tending grapes and some new machinery, destemmers and grape presses!!
    For the most part there are 40 and 50 microliter streams
    That is 40 or 50 microliters per board
    I would not be spraying any lanes
    For a plastic ball tournament I would be running a 7 or 8 mil pattern
    I will design one if you wish
