Murrey Lanes and Phoenix-s
  • Murrey Lanes and Phoenix-s
    Need a pattern for New Murrey lanes and a phoenix-s. I have infinity or prodigy conditioner to use. Any ideas?
    This is a silver box with transfer rollers also.
    50 mic stream
    41 feet
    19.65ml
    2-2 2 18
    8-8 1 18
    9-9 2 22
    10-10 3 22
    11-11 2 26
    12-12 1 26
    2-2 0 26 31-41
    2-2 0 30 41-28
    12-12 1 22
    10-10 3 18
    8-8 2 18
    2-2 0 12-0
      Use the Prodigy - Infinity may cause ball call issues if used too heavily - or without sufficient taper
        King,
        Pattern plays wide open if you keep ball speed up and swing the ball some. What would be a good adjustment to make the whole pattern a little wetter or wider?
          Bump for king!
            There will be much less transition with the pattern below - much more lengthwise taper
            Please let me know how it plays!
            50 mic stream
            41 feet
            19.65ml
            2-2 2 18
            8-8 1 18
            9-9 2 18
            10-10 3 18
            11-11 2 18
            12-12 1 18
            2-2 0 22 25-41
            2-2 0 30 41-28
            12-12 1 22
            10-10 3 18
            8-8 2 18
            2-2 0 12-0
              Jerry,
              That still played pretty dry. maybe not dry but very early rolling. I went to infinity and back to your original pattern and added one 2-2 load. Seems much better but plays kinda funny. Not sure how to describe it yet. Going to bowl more this week.
              Thank you
                Are the lanes hooking in the middle? - no hold?
                Adding a 2-2 will not help with hold
                  8-8 1 18
                  9-9 2 22
                  10-10 4 22
                  11-11 2 26
                  12-12 1 26
                  2-2 0 26 33-42
                  2-2 0 30 42-28
                  12-12 2 22
                  10-10 3 18
                  8-8 2 18
                  2-2 0 10-0
                  Try this at 42 feet
                    King, they were hooking alot once the ball hit 6 or 7. There wasnt any way to get the ball down lane if playing outside. Inside that, they weren't as hooky, but there was still a considerable amount of friction.
                    You know, if my dog was as ugly as you. I'd shave his butt and tell him to walk backwards
                      7-7 1 18
                      8-8 2 22
                      10-10 4 22
                      11-11 2 26
                      12-12 1 26
                      2-2 0 26 33-4?
                      2-2 0 30 4?-28
                      12-12 2 22
                      10-10 3 18
                      8-8 2 18
                      2-2 0 10-0
                      Try this at 41 & 42 feet
                      You will see what you like quickly if you throw a couple different style balls on each
