Special Event pattern needed
  • Special Event pattern needed
    We are having two bowlers attempting to break the world record for pin fall in a 24 hour period on the 11th of August. I was hoping for a suggestion for a pattern to put out, to last as long as possible for 2 talented right handed crankers! They suggested the most recent USBC pattern, but I think we can do better than that! I will be allowed to re oil once during this period. I believe reason is for protecting surface of lane! We have a K Plus machine, W-22 conditioner, Invincible cleaner @ 6 to 1 and one year old anvilane. Thank You!
    http://kegel.net/V3/PatternLibraryPa...ta.aspx?ID=599
    Kegel Challenge broadway - this will allow them to start to the right so the center of the lane does not get beat up
    There is enough volume for longevity
    Tell the bowlers to start playing up 5, 6, 7 board
      Thanks King! I post back about how everything went after event. Getting them to start playing the lane where you recommended, might be the hardest thing they do!
        If they start in deep - there is no where to move to
          Well, if they start in deep, the only ones they will be hurting will be themselves. If you tell them how to start then I guess that is all you can do!
            Short update. Put out the Broadway, so one of them could practice on, and it was well received. Thanks! We are also demo-ing the Ion Sport ED. right now, so program already in. Even easier to do on my end! Thanks for suggestion! I will be back in a few days to let know how it went.
              It is the perfect pattern for long events
                Great news! The record was broken. They ended up knocking down 28,228 pins in the 24 hour period. I believe the record was 27,4??. We started out using the Kegel Broadway pattern. After 4 hours it was difficult for them. We changed to the Dead man's Curve pattern for the second 12 hours, and it gave them more play time where they like. I am pretty confident they did not take the recommendation of were to play for the broadway. The whole event was recorded, so I am sure some could be on youtube, I will let ya know. On a side note, we had 3 stops on lane #5. At 8:30pm, we had double five pin in deck chute, then @ 10:30pm we had an OOR, then 11:15pm another OOR. Then it ran peacefully for the rest of the event!
                  Good job to all!
