Changed oil-need to adjust pattern
  • Changed oil-need to adjust pattern
    Hey King, need a little tweaking on this. I was using navigate before with fission cleaner and running pattern 44ft for last 10 yrs. I tried a pattern that you posted here for wood in the spring. here is the one I've been trying out.
    Kustodian w/transfer brush-no rbd
    50 mic-42 ft -20.55 total volume- (the pattern you posted was actually 41ft)
    2-2 2 14
    8-8 1 14
    10-10 3 14
    11-11 2 18
    12-12 3 18
    2-2 0 22 22-42
    2-2 0 30 42-31
    13-13 2 22
    11-11 3 18
    9-9 2 18
    7-7 1 18
    2-2 0 18 9-0
    The shot and the hold seem to disappear by the end of practice. I'd like to keep it at 42 ft as most other houses in the area are at that distance or shorter. I had a screen and recoat done 2wks ago and heads are in good shape. It seems as there is no hold in the middle after a couple of shots. We have 5 man teams with very competitive bowlers. I was at 23 ml with my 44ft shot. Recommendations or suggestions?
    8-8 2 14
    10-10 4 18
    11-11 2 18
    12-12 1 18
    2-2 0 22 23-42
    2-2 0 30 42-31
    13-13 2 22
    11-11 3 18
    9-9 2 18
    7-7 1 18
    2-2 0 18 9-0
    Lets try this - should give more push
      Thanks, I will try this a few nights and report back this wknd
        Yes - give it a couple days - we can tweak again if needed
          The shot is definitely better but opens up and goes away to quick for the majority of the bowlers. It needs a little more hold. I realize my previous pattern with navigate was 23ml at 44 ft so its bound to play more wide open, just trying to get a little more longevity with this infinity. I would rather widen it more or increase speeds than increase buff distance. What do you think?
            8-8 2 14
            10-10 4 18
            11-11 2 18
            12-12 1 18
            2-2 0 22 23-43
            2-2 0 30 43-33
            13-13 2 22
            11-11 3 18
            9-9 3 18
            7-7 1 18
            2-2 0 18 9-0
            22.35 volume
            43' pattern
              I will try it out and report back in a few days. Thanks alot!
                Welcome
                  Seems to be working fine now. Thanks
                    Great!
