how to eliminate extreme carry down.
  • how to eliminate extreme carry down.
    Here is the pattern I currently am having a problem with. Starts out like a dream shot but after about 7 frames oil carries down so bad that the ball just slides 45 feet.
    Start Stop Loads Speed Crossed Start End Feet T.Oil
    2L 2R 2 10 74 0.0 1.4 1.4 2960
    5L 5R 1 10 31 1.4 2.8 1.4 1240
    7L 7R 1 10 27 2.8 4.2 1.4 1080
    10L 10R 3 10 63 4.2 8.4 4.2 2520
    11L 11R 3 14 57 8.4 14.3 5.9 2280
    2L 2R 0 18 0 14.3 24.0 9.7 0
    2L 2R 0 22 0 24.0 33.0 9.0 0
    2L 2R 0 30 0 33.0 39.0 6.0 0
    2L 2R 0 30 0 39.0 33.0 -6.0 0
    13L 13R 3 18 45 33.0 25.4 -7.6 1800
    12L 12R 3 14 51 25.4 19.5 -5.9 2040
    11L 11R 4 14 76 19.5 11.6 -7.9 3040
    10L 10R 3 10 63 11.6 7.4 -4.2 2520
    2L 2R 0 10 0 7.4 0.0 -7.4 0
    total volume is set to 40
    distance is 39 ft.
    reverse oil starts at 33
    What kind of oil?
    Do you have a transfer brush?
    Do you have reverse brush drop capability?
      I am far from a lane machine/ conditioning expert, but it looks to me like you have a VERY large amount of oil on the lanes.
      In this thread: http://www.bowltech.com/forums/showt...-and-Phoenix-s King told us to put 11 loads on the forward pass at 50mic, and 6 on reverse.
      You have 10 loads forward at 40 mic, and 13 reverse. My guess would be too much reverse oil for the lanes.
      Hope it helps.
      Cody
      You know, if my dog was as ugly as you. I'd shave his butt and tell him to walk backwards
        Reverse oil is your "hold" oil.
          Remember, if you have to much carrydown, then there is to much toward end of pattern. eventhough reverse oil is your hold, it might be alittle too much in this case and you can start it further back on the reverse. meaning around 29' or so. Also, remove a load, like an 13. If is starts out dreamy, make smaller adj. and go watch reaction, until desired results. Maybe the forward 5 to 5 could go away.
            There can also be massive carry down is there is oil too deep in the heads - that is the issue here
            I will modify your pattern and repost in a few minutes
              39 feet
              40mic stream
              Volume 19.48
              2-2 2 14
              5-5 1 14
              7-7 1 14
              10-10 3 18
              11-11 3 18
              13-13 2 18
              2-2 0 22 26-39'
              2-2 0 30 39-33'
              13-13 1 22
              12-12 3 18
              11-11 4 14
              10-10 3 14
              2-2 0 14 8-0'
              Let me know how it plays please
