Phoenix 8 Pad Phoenix - Looking for a little more hold without Carrydown..
  • Phoenix 8 Pad Phoenix - Looking for a little more hold without Carrydown..
    Hello again,
    8 Pad Phoenix using Kegel Crossfire Oil and Cleaner..
    Looking for more hold in the middle than we currently have. Pattern plays pretty dry..
    Clean (1) Oil (2) Both (3)
    Simultaneous (1) Sep (2) 2
    Start clean distance 0
    Spray "on" time (tenths) 4
    Spary "off" time (tenths) 12 or 30
    Last spray distance (feet) 46
    Oil pattern distance (feet) 40
    Forward shift to 2nd speed 10
    Forward shift to 3rd speed 11
    Forward shift to high speed 12
    Rt 1-7 oil forward (inches) 32
    Rt 7-10 oil forward (inches) 110
    Rt 10-15 oil forward (feet) 31
    Rt 15-20 oil forward (feet) 34
    Lf 1-7 oil forward (inches) 14
    Lf 7-10 oil forward (inches) 100
    Lf 10-15 oil forward (feet) 31
    Lf 15-20 oil forward (feet) 33
    Return shift to 3rd speed 40
    Return shift to 2nd speed 19
    Return shift to low speed 1
    Rt 1-7 oil reverse (inches) 0
    Rt 7-10 oil reverse (inches) 110
    Rt 10-15 oil reverse (feet) 33
    Rt 15-20 oil reverse (feet) 37
    Lf 1-7 oil reverse (inches) 0
    Lf 7-10 oil reverse (inches) 90
    Lf 10-15 oil reverse (feet) 33
    Lf 15-20 oil reverse (feet) 37
    Add oil Rt 1-5 (# hits)
    Add oil Rt 5-10 (# hits)
    Add oil Lf 1-5 (# hits)
    Add oil Lf 5-10 (# hits)
    I also use a pad machine on Murrey Lanes, and I find 40 ft. to be too short for a house pattern. Mine are in the 41-43 range, with my current one at 42. I would try your same pattern at at different lengths before tweaking the pattern. JMO.
      Oil pattern distance (feet) 42
      Lf 1-7 oil forward (inches) 32
      Return shift to 2nd speed 28
      Return shift to low speed 15
        How did you get that in spreadsheet format king?
        Charley
          Thank you everyone.. I am very thankful for your help.. I will let you know how it turns out..
            I ran this pattern tonight and anything outside 7 wouldn't come back but a very smooth shot down second arrow. Why do you have the spray shutting off at 46 feet? I'm going to try it again tomorrow after adjusting the spray jets more towards the outside. Thanks King it's better than what I had.
              Clean (1) Oil (2) Both (3) 3
              Return shift to 2nd speed 20
              I would agree with the smooth shot down second arrow..
              Above is the modification of the pattern I ran tonight. Only Change I made was the return shift to 2nd speed by 1 foot. We had 2 series over 730 on a league that may have 5 700's all year.
              I put out the exact recommended pattern before league and threw on it, I could have made it work for me, but 75% of my league bowlers would have been 2-8-10 all night. It was significantly oiler than I needed for this league.
              After league with the one modification, I was told by several people they didn't even have to move a board tonight.. Less transition should equal higher scores..
              Again, Thank you King and everyone else for your input..
