Need help with pattern
  • Need help with pattern
    Would appreciate your input on our lane pattern. Right now down and in players are having trouble getting the ball to wrinkle if they are playing in the track or outside. Even guys that can hook the ball are saying the lanes seem slick and have to play pretty deep to get near the pocket. We have pretty old wood and have always had to use a large volume of oil to tame the lanes some, but now the friction seems to be gone. Last resurface was in summer 2011. Using a Kustodian, no RBD, Navigate oil, Defense c at 6:1. Backends seem to be getting clean, so not sure where to start in tweaking the pattern, any help would be appreciated.
    40 ft pattern pump at 50ul total vol 23.7ml
    2-2 2 10 1.4
    8-8 1 14 3.3
    9-9 1 18 5.8
    10-10 2 18 10.9
    11-11 1 22 14
    12-12 2 22 20.2
    2-2 0 22 34
    2-2 0 30 40
    rev
    2-2 0 22 34
    13-13 1 18 31.5
    12-12 3 18 23.9
    11-11 4 14 16
    8-8 1 14 8.2
    7-7 1 14 6.3
    2-2 0 14 0
    I would do a test clean - you do not say if it is a Kusty Plus or a spray model
    You need to check the duster cover too
    I do not like the forward speeds in the 22 and 30 ips so early trying to clean all the oil and dirt from the previous day
    Try these small tweaks and let me know
    2-2 2 14
    8-8 1 14
    9-9 1 18
    10-10 2 18
    11-11 1 18
    12-12 2 18
    2-2 0 22 21-40'
    rev
    2-2 0 22 40-32'
    13-13 1 22
    12-12 3 18
    11-11 3 18
    9-9 2 14
    2-2 0 14 9-0'
    20.25 ml
      It is a sprayer. When I put the pattern into Kosi Pro I get the forward pattern only going 19 feet and the total volume of 19.3ml, did I miss something? Will the forward distance matter?
        Sorry - I took that revers 11 and moved it to forward and forgot
        This is correct
        Let me know how it plays
        2-2 2 14
        8-8 1 14
        9-9 1 18
        10-10 2 18
        11-11 2 18
        12-12 2 18
        2-2 0 22 21-40'
        rev
        2-2 0 22 40-32'
        13-13 1 22
        12-12 3 18
        11-11 3 18
        9-9 2 14
        2-2 0 14 9-0'
        20.25 ml
          Lanes played much better, but seemed to get snappy after about a game and a half. Should we change anything or maybe add distance? Thanks for the help
            8-8 1 14
            9-9 1 18
            10-10 3 18
            11-11 2 18
            12-12 1 18
            2-2 0 22 21-40'
            rev
            2-2 0 22 40-32'
            13-13 1 22
            12-12 3 18
            11-11 3 18
            9-9 2 14
            2-2 0 14 9-0'
            Small tweak to stop breakdown
