alright we have some bowlers that think our shot is to easy and was needing input on tweaking the pattern to get a little more difficult shot.
8 pad configuration 7-3-5-5-5-5-3-7 3 speed machine. authority 22 oil jayclean mixed 4:1 brunswick prolane
Not that it matters much but you are a 4 speed machine if this is indeed your pattern. It must really hook alot? I've tried many different patterns over the years but these two have been the best out of them all. These both came from "The King" a while back. Your surface might dictate changes in them.
Scratch Travel League Pattern - 42ft
Shift to 2nd - 16
Shift to 3rd - 41
Shift to High - 42
Forward Oil
30in
180in
36ft
39ft
30in
180in
36ft
39ft
Shift to 3rd - 41
Shift to 2nd - 30
Shift to low - 18
Reverse Oil
0in
70in
33ft
35ft
0in
70in
33ft
35ft
This was a pattern I got from "The King" a few years ago and have used it in a few different centers on various surfaces. I've used it mostly on HPL and Wood with good results.
Here is the same general pattern for my typical house bowling leagues. A little less oil than the pattern above. I'm sure there are many other patterns and suggestions you maybe able to go with. See what everyone else thinks on here before you make a drastic switch of condition.
Normal House Pattern - 42ft
Shift to 2nd - 8 Shift to 3rd - 41 Shift to High - 42
Forward Oil
30in 120in 33ft 36ft
Shift to 3rd - 41 Shift to 2nd - 30 Shift to low - 18
