Help with HPL's
  • Help with HPL's
    I have about 12 year HPL's and just started this oiling job at the beginning of the winter leagues so i am trying to learn this as i go along. Im getting better at pattern tweaks but I just can't quite get it figured out. I am using a Kustodion Ion B, Prodigy oil and defense-c cleaner. My down and in bowlers struggle getting to the pocket to start and then by the end of game 1 the carry down is so bad they can barely get to the head pin. For the other players the only complaint is the carry down is a little much. Any help would be greatly appreciated
    50 mic stream
    cleaner 5:1 @ 30ml per 4 streams
    41ft
    2 2 2 10
    8 8 1 10
    9 9 1 14
    10 10 2 14
    11 11 1 14
    12 12 3 14
    2 2 0 18 to 30'
    2 2 0 22 30-41
    RDB 38
    2 2 0 30 41-34
    13 13 2 18
    12 12 2 18
    11 11 2 18
    10 10 3 18
    9 9 1 14
    2 2 0 10
    20.65ml total oil
    I feel like its real close if i could eliminate some of the carry down issues
    In Kosi I come up with 21.1
    Your pattern - I cannot believe it works on HPL
    In my opinion Prodigy is too light for that surface
    I would check the oil pump volume
    2-2 2 18
    7-7 1 18
    9-9 1 18
    10-10 2 18
    11-11 3 18
    12-12 1 18
    2-2 0 22 22-41
    2-2 0 26 41-34
    13-13 1 22
    12-12 3 18
    11-11 2 18
    10-10 3 18
    9-9 1 14
    2-2 0 10
    RBD 37'
    Volume 21.5
    50mic stream
      The reason for all the carry down - all the slow speeds is just dumping oil in the head area - and the balls are getting huge oil rings - then depositing that oil down lane
        Thanks. Next league is Wednesday I will try it then and let you know how it plays. What oil would you recommend? i have been thinking about trying Infinity this summer. I dont really want to do anything too drastic for the winter leagues.
          I would not change oil immediately...lets see how this tweak plays out
          What kind of ball return system in your 70's?
          Kickers - PBL?
          Ball return up front? - power lift?
          You need to be careful with 70's because the wrong oil can cause issues
            If Prodigy carries down too much, look out for Infinity.
