Need an nice easy to moderate pattern
  • Need an nice easy to moderate pattern
    Hi Jerry,
    What would be an ideal pattern to set up in the centre I have taken over as H/T in, the machine they have is a Crossfire using W22 oil, Defence C cleaner, lanes are B/Wick ProLane, at the moment there is no league there just social, but we are trying to develope leagues there and would like a nice easy to medium pattern just for the guys starting out, to attract new league bowlers I kinda don't want them thinking it's some sort of sport house if ya get what I mean....
    Again as awlays Jerry many many thanks in advance......
    Cheers Brett....
    2nd speed - 8'
    High speed - 40'
    Total distance 40'
    Pad 1 - 36"
    Pad 2 - 100"
    Pad 3 - 31'
    Pad 4 - 34'
    Reverse
    2nd - 30
    low - 16
    Pad 1 - 0"
    Pad 2 - 60"
    Pad 3 - 30'
    Pad 4 - 30'
    I think Crossfires are 3 speeds
    Let me know if it needs a tweak!
      Will do, thanks a billion Jerry...
      yeah mate, after reading the manual they are indeed a 3 speed...
        Hope you guys are well!
          We are indeed thank you kind sir, I am looking forward to trying that pattern in the Crossfire, never used one before as I have been given control of a 2nd centre, so now I have 46 XLi's, very happy though I still have my Walker at my big centre....
            G'day Jerry,
            Well that pattern finally got tested by actual decent bowlers today and they loved it, thanks heaps mate...
              Awesome!
                King, can u modify this pattern for 7-3-10-10-3-7 and wood lanes using crossfire oil?
                  2nd speed - 8'
                  High speed - 42'
                  Total distance 42'
                  Pad 1 - 36"
                  Pad 2 - 100"
                  Pad 3 - 33'
                  Reverse
                  2nd - 30
                  low - 16
                  Pad 1 - 0"
                  Pad 2 - 60"
                  Pad 3 - 33'
                    Ok a couple questions: 1. Where should i drop the brush
                    On the reverse?
                    2. With my machine, i cant have the 3rd speed forward
                    The same no. As the pattern length so is this a 42' or 43'
                    Pattern?
                    3. My machine came (cleaning wise) preloaded as 4/10 and
                    Every 30" but i changed my no. To clean like your no., my
                    Question is which is a better clean if i cant see or feel the
                    Difference after a test clean?
                      Set the RBD to 36'
                      Pattern length is 42 - so set the high speed to 43
                      4/10 and 30 inches always pushed too much cleaner off the tail plank
                      If you mix your cleaner correct at 5 or 6 to 1 then you do not need that much cleaner
                        HI Jerry,
                        Could you come up with a slight tweak to get a similar result, as a Head Tech at a sister centre also with a Crossfire loves the pattern you gave me but he said his Crossfire only has the 3 pad zones not 4. So with that in mind could you come up with something very similar to what you gave me but with 3 zones instead.
                          Originally posted by Pin_Head View Post
                          HI Jerry,
                          3 pads each side
                          You can upgrade to 8 pads
                          This is the 3 pad zone pattern - did they try this one?
                          2nd speed - 8'
                          High speed - 42'
                          Total distance 42'
                          Pad 1 - 36"
                          Pad 2 - 100"
                          Pad 3 - 33'
                          Reverse
                          2nd - 30
                          low - 16
                          Pad 1 - 0"
                          Pad 2 - 60"
                          Pad 3 - 33'
                            I think they will be upgrading to 4 pad zones like my centre has, that previous pattern was actually for me Jerry as I run 2 centre's now one with a Walker and other with Crossfire but mine has 4 pads zones. I will give that new one to them and let you know how they go, again thank you kindly my friend!!
                              2nd speed - 8'
                              High speed - 42'
                              Total distance 42'
                              Pad 1 - 36"
                              Pad 2 - 100"
                              Pad 3 - 33'
                              Pad 4 - 36'
                              Reverse
                              2nd - 30
                              low - 16
                              Pad 1 - 0"
                              Pad 2 - 60"
                              Pad 3 - 33'
                              Pad 4 - 36'
                              The extra pad is broken at 15-20 board spot I believe
