Machine stays in low speed on forward travel
  • Machine stays in low speed on forward travel
    I have a Sanction Standard SE that once in a while stays on 10 ips in forward travel. When it gets to the end of the oil it goes back to normal speed. Doesn't do it very often and never saw it do it on reverse travel.
    The Kegel tech support team is available to help you. Call 1-800-280-BOWL. The techs are all working from home, so calls are being forwarded to them via our answering service.
    let me be myself
    Help-broken Part
    Greeting all.
    Thanks for looking.
    Bolton454
    Pin Damage
    Making TDM's adjustable.
    1:1 shaft wear
