Members
- Mar 2015
- 294
- Brunswick A2
- AS/80 with 79 scanners
- Brunswick Envoy
- Bruns Armour Plate
- 1985
Doesn't Brunswick have a life time warranty on this lane system? Must have had a defect at manufacturing to cause this problem so far out from the foul line.
I think there is. I also have another lane with an identical crack in the same spot, just not as pronounced.
Members
- Jun 2018
- 251
- AMF 82-90XL, XLi EDGE
- Qubica BES-X + SuperTouch
- Kegel IKON, Kustodian +
- DBA IQ
- 2006
How old? We have several arrow panels of 20 year old DBA IQ/Brunswick Anvilane with similar cracks and I replaced one of them about 2 years ago because the crack was higher on the pin side and worsening. Subfloor from that section to the pin deck is our original 1963 wood lanes, I believe our heads have HDF underneath.
We also get those cracks on the approach/heads panel a few inches before the foul line, I have replaced two of those panels in 2 years for that same reason, the crack faced the wrong direction and I didn't want bowlers' shoes to catch on the crack during their slide.
I don't have a method to repair them. Typically the underside of the cracked panel reveals a spiderweb of cracks in addition to the one that reached the surface.Don't let those quick fixes become permanent ones; the job is not done until it is done right.
Well, they came from another center that closed where I believe they had it been used for maybe 7 years? I'm not really sure though. We've had them installed for roughly 7 years. During the installation the foul lines were moved back about 6 feet so all of the old wood lanes underneath were cut and shifted around. I wasn't there for most of this part but I know it was a lot of work lol
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
