Synthetic Overlay Approaches has some raising.
  • Synthetic Overlay Approaches has some raising.
    I have an issue with my approaches. Some of my approaches have some raising on every other lane. The build has been shut down for almost 3 years with out any climate control.
    Will the panels lay back down since I finally got the AC units running and the damage to the building repaired and sealed up? So I can try to get the humidity down inside the building.
    Thanks
    If only the glue failed you can try weighting them down and if that will bring them down enough let them back up, add construction adhesive or epoxy, and weight them down again until it dries.
    If you plan to get USBC certified get a lane level and check all the lanes because they may have raised enough at the edges that they won't pass.
