silver bullet problem
  • silver bullet problem
    Here's the prob. Machine runs so far down the lane and then stops. Display says encoder drive error. I'm told it is the speed control box causing the problem from one guy, and the amf ( I think means Adios Mother %^$#&^ ) tech says it is the drive motor in either case it cost bucks ($900 for one and $1000 for the other). Hard to believe a machine 4 years old and only does 12 lanes a day can take a dump like this. Right now I'm using 100B. Thanks for the help.
    Ron M
    Re: silver bullet problem
    Ron,
    We had a similar problem not too long ago. It doesn't happen anymore, but this is what we did. We swapped out the box on the 7-pin side of the machine. Also, we swapped out the power cord. Not for sure what was going on. I hope this gives you a little help. If I am not specific enough, let me know.
    Bye for now,
    Joey
      Thanks for responding. I changed the speed control box, and it did not change. We allready changed the cord. I don't know where to go from here except maybe processor.
      Ron M
        Ron I had one of the first Silver bullitts ever made actualy it was this first one made. Any how we had the same problem with ours and we found that the distance counter had gone bad and we changed it and the problem went away.
          Dustin;
          Thanks for responding. I changed the the distance counter last night. I hope this fixes it.
          Ron M
          • evilian
            Silver Bullet troubles
            by evilian
            We use a silver bullet to oil our lanes with but on occasions we set it up on the lane hit the go button and nothing happens when you push the button the screen goes blank then...
            09-16-2003, 12:56 AM
          • down under mate
            SILVER BULLET MAGNUM GOING NO WHERE FAST
            by down under mate
            OUR SILVER BULLET IS DEAD. THERE R A FEW PROBLEMS WITH IT.1 WHEN IT IS GOING DOWN THE LANE IT SLOWS DOWN SPEEDS UP AND AT TIMES STOPS. 2 WHEN IT GETS TO ABOUT 45' MARK IT SPEEDS...
            10-05-2003, 08:01 AM
          • Guest's Avatar
            silver bullet
            by Guest
            We are experencing a new problem with our Silver Bullet lane machine.
            Our lane oiler/stripper has decide to at times jump off the back of the pin deck instead of...
            02-08-2000, 08:14 PM
          • TPJ
            Silver bullet magnum unstable
            by TPJ
            I have a silver bullet magum which is very unstable when it is upright. I tried the double castors but this did not help. I heard that some people were using skate board wheels...
            06-12-2009, 06:53 PM
          • evilian
            Silver Bullet Vibration
            by evilian
            We have a Silver bullet magnum which we have a strange problem with it has a vibration as its going down the lane.
            The strange bit is its not there when we first start it...
            10-22-2004, 12:39 AM
          Baddest Tool Chest In Town
          Adios, motor boater!
          check this jam...
          the ball stuck the table up
