phoenix pad machine
  • phoenix pad machine
    Problem set on the lane push button won't go
    setting on lane good push button on the approach
    gives msg put machine on lane but then when you
    push it to go it won't any ideas ???
    Re: phoenix pad machine
    Lino-switches? Never seen that be the problem. but that's the only thing I can think of that would "know" if it's on the lane or not. Are you getting a "forward travel interupted" error? For s**ts and giggles have you checked all the fuses and breakers on the machine?
    Alex
    Cloth: ShamWow!
    Machine: Johnny 5
      THANKS FOR THE REPLY BUT I BELEIVE YOU WERE
      RIGHT.TOOK OUT LINO CLOTH REPLACED THEN NOTICED
      THERE WAS SCREW MISSING OUT OF ONE OF THE SWITCHES
      SO CAUSED IT TO MOVE AROUND.RAN MACHINE TODAY
      WITH NO PROBLEM.HOPEFULLY THAT WAS IT !!!!
        Glad to see you got it going again.
        Alex
        Cloth: ShamWow!
        Machine: Johnny 5
        Baddest Tool Chest In Town
        Adios, motor boater!
        check this jam...
        the ball stuck the table up
