Phoenix Pad Machine Problem
  • Phoenix Pad Machine Problem
    Hello all, I have a phoenix pad machine and today while oiling the machine stopped about 30 feet down the lane, forward travel interrupt error, no biggy, When I tried to start the machine again, I received a buffer not up error. Can't figure out how to get everything bck to normal ....
    Please help.
    Tried the Output test on #205, did nothing.
    Thanks in advance. Step by step would be great if you know.
    Re: Phoenix Pad Machine Problem
    Check your buffer switches and check if you get voltage towards buffer up/down motor
      Is it the Phoenix 3 speed or 4 speed?
      3 leftover nuts and 5 leftover washers... but it's running.
      Baddest Tool Chest In Town
      Adios, motor boater!
      check this jam...
      the ball stuck the table up
