Phenolic kickback plates
  • Phenolic kickback plates
    Phenolic kickback plates from Brunswick
    21-088675
    $157 each
    Phenolic kick plates from EBN = much cheaper. Phenolic kick plates from Felix Erickson = $79 AMF and $84 Bruns.
      I get a sheet of plastic from a local plastics co. cut it up and bevel the edges. (cheap)
        We also manufacture the canvas backed 3/16" thick phenolic kickback plates. Many techs are not fans of the newer plastic style.
          If not installed right they will stretch and bubble. I use a brad nailer, every 1 1/2 in. top to bottom leaving a 2 in. gap at the bottom where the ball touches.
            Thanks!
              Western Pacific $72
                21-088675
                $157 each
                Dam near choked on my dinner,
                Holy crap.....
                  Very interesting,
                  A brad nailer......Hmmmmmm that would be easier, U glue also ?
                    Originally posted by MASTERMIKE View Post
                    Very interesting,
                    You can glue but it does'nt stick to plastic, but it will fill up any voids from hammer dents and stuff.
                      My biggest trouble with kickback plates is getting the old glued ones off. Usually come off in many pieces. I install the new ones with drywall screws (countersunk). No glue. I don't have any problems with the screws.
                        I also use Durham's rock hard water putty to fill up the voids.
