Kegel Kustodian Model C with Reverse Drop Upgrade
When powering the machine up, oil head will travel to the 10pin side of the machine past the proximity sensor and bang against the frame of the lane machine. The motor will not reverse back to the left---even when past the proximity sensor and at the frame, the motor continues to pull the head to the right. The only way to get it to stop is to remove the L2 Relay or to power down the machine. I have switched the relays and everything else can think of, but cannot get the oil head to reverse directions. The only way it will travel to the left under normal conditions is to remove the Left-to-Right relay. It will travel normally to the left wall and try to reverse, but then can't due to lack of power.
Any help would be greatly appreciated--currently without a machine
