oil on approach
Originally posted by Jan-Willem View PostApproach spot cleaner Brunswick 62-860034-004
AMF 294-007-037
If a big amount on wooden approach 294-007-078 Oil lift absorbent compound box 50Lb.
Quite some year ago i used salt on an area oil was spilled on and soaked into wood approach, It worked quite well with no affects
MikeDO A NEAT CLEAN JOB, AND FIX IT RIGHT THE FIRST TIME. THE ONLY WAY TO WORK.
I always use approach spotter, then follow up with approach conditioner using a 15" floor buffer with a white pad or burlap and go over the whole slide area so that it is consistent and not spotty.
