Dirty Lanes
  • Dirty Lanes
    like the title says, the lanes and pindecks are dirty on certain lanes. Some of them look nice as I've cleaned them and they seem to have stayed clean, others are getting dirty again and again. these pics aren't even the worst ones but there is clearly some build up. any ideas if this is a pinspotter issue or a lane machine issue? what should be done?
    Grit, my pindeck edge boards look the same. (3 yrs. old) I think just a low design. The splices on mine are 85% good, but the rest are alot lower and the crud builds up. Mach. can't clean it when it does'nt touch it.
      Mine do the exact same thing. All the centers that I service are the same also.
