Guardian on Pindecks
  • Guardian on Pindecks
    How does guardian on pindecks over the years effect pin carry, anyone else have this done over the years? We have 22' on the heads then wood , and guardian on the decks. about 15years on the decks, the 22' has been replaced once. Just wondering if pulling if off would help improve pin carry, ? Thanks
    Do you have alot of sliding pins that stand up? If not that will not help carry. Deck going up hill, Tight and supported flat gutters, and good kickback plates. Not having a large sky jump in front of the head pin helps alot. (soft wood to hard wood)
      Just rarely see any mixers like in years past, seems like they get knocked down, and just lay flat, not rolling around or messengers. Thanks for the reply, I suppose a new set of pins is in order too.
        Pins are part of carry, I think good ball reaction will knock down anything.
          We have had guardian on out pindecks since they put the lanes in and that was 1990. Its been replaced every time theyve done the lanes and they replaced the guardian on the decks this year when they did a full sand (August 2011) and elected to not use it on the heads. Scores have gone thru the roof this year.
          If your carry sucks, then make sure your backend is tight, check flatgutters, pindeck, kickbacks and kickback panels etc...
