Sliding pins
  • Sliding pins
    What are some of the better methods of stopping out of range pins on newly installed synthetic pin decks?
    Uniflex waterbased basecoat. Paint roller ( 8" square over the spot)
      It is illegal to coat synthetic decks with lane finish
      I would be checking the cleaning part of your machine ...and look at your pattern for correct lengthwise taper
        There is a difference in thinking your decks are clean and knowing your decks are clean. Everytime we spot pins its a cleaning related issue, either the machine isn't correct of the ratio of cleaner to water or type of cleaner is incorrect.
          King, I understand the rules, when it comes to all the rules this does'nt do anything but stop people from getting pissed off. You can use other products to do the same thing. Are they legal because they've paid to be approved.
            Please ost your pattern here so we can see how it looks
              I am all for bending the rules ...however it is not needed to rid yourself of the sliding pin issue....unless you use Twisters
                I also have noticed a sliding pin issue when it comes to twister pins. The same goes for Diamond Duramid pins, which are not around any more, but may be the same as the us strike pins (because Ebonite aquired the DD company plant equipment )
                Nick
                  Id fight that one. Been putting base coat on decks for years. Gerald, do you have a link to were this rule may be read? I wouldnt mind shooting an e mail off to the USBC.
                  Thanks
                  Charlie
                  Please buy MADE IN USA!
                    http://usbcongress.http.internapcdn....ecs-manual.pdf
                    Page 29 - Surface
                      I'm sure it could be argued that the next page covers the "pin deck" which in my mind would separate it from the regulations of the lanes since they have taken the time to cover both areas and and the pin deck regulations does not mention the same as the lane that it may not be altered. That may explain why its never been a factor in the centers that I ran with the decks coated. Just a thought to ponder.
                      Thanks for the link.
                      Charlie
                        Could be - they do allow the no slide spot - however they also say the coating must be tested for approval.
                        I would think that if someone submitted base coat for approval - marked EBN on the can - there could be some profit in doing so
                          So as usual, workin man has an easy solution, but govt is in the way.
                            Maybe I could mark it up 600% and retire.
                            Charlie
                              sliding pins
                              I clean my lanes daily during leagues and every other day i go down with a magic eraser pad and cleaner and clean the pin decks, I hardly ever have any OOR's
                              and that also gives me a chance to look things over
