Flipping vs. synthetic
  • Flipping vs. synthetic
    I have a friend that just purchased a bowling center. He was wondering about flipping just the heads or just getting synthetics on just the heads. Also wondering how hard to replace the pin decks. Im not really familiar with this subject so I will leave the answer to the Bowl-Tech family.
    I have heard of flipping the pine and replacing the heads
    It is prudent to get synthetic - used are available - replace the entire lane
    Changing the pindeck requires a lot of work
      I would not recomment flipping the lanes over. not only will the lane base become marganially thin, all the cull wood is placed down when the lanes are nailed up. You may pay mucho dinero for replacing boards and filling holes and patching out knots, and still have a thin lane that will be prone to major damage if you let prople keep throwing those 15lb balls onto them.
        Seen it done, Ted hit the nail as the ball will too right on the head. There is no savings with this practice, only a lot of work and expense.
        JMHO
        Charlie
        Please buy MADE IN USA!
          I worked at a center that replaced the heads and pindecks with synthetic and they had no problems. I do not however know if they had any issues while installing or removing the pindecks as it was done before me. I have swapped out synthetic for synthetic pindecks but that is a lot different than going from wood to synthetic.
            Done that in many centers smurtland, it's just such a hassle when you have to sand the pine and still keep from having a huge drop-off from the head to the pine. there is usually some shim at the end of the head panel. But eventually, this setup needs to have the underlay at the end of the head tapered down so the panel end has the drop off onto the pine in spec.
              Pin Decks are not that hard to change I did 30 lanes worth of them when I was in Toledo.
                I don't know the $ and cents, but I would think if you're going to do heads and pin decks, If you did them all the way it would pay off in the long run. (big investment but it pays you back every yr.)
                  Its only an 8 lane center. I told him that putting in full synthetics would be the smart thing to do. Is used the way to go or new?
                    Good used are real hard to find. If one does find any used syn, one better make sure they can still get the dowels for them. There are a couple versions being used today where the dowels are discontinued.
                      Ted, are full synthetics the way to go in your opinion? Or keep wood approaches and just do the lane.
                        With the manufacturers all now making the textured approach, I'd go for all syn and forgo the maintenance and repairs of wood. Although I just did a 'foul line forward' this winter, it was the choice of the proprietor. We sanded the approaches half way through the lane install so there won't be any maintenance for a few years.
                        Wood approaches was the thing before textured came out, and there are still a lot of apprehension because of the pre-texture approaches causing sticking issues with weather changes.
                        If you were leery about them, ask some centers that has had textured approaches for a few years. Nothing better than unbiased opinions.
                          We have 2 centers with wood approaches and synthetic lanes, 3 with full textured synthetics. Given a choice, I would have the wooden approaches replaced with textured synthetics, but that's because I don't enjoy doing the patching/sanding/application every year!
                            Full synthetic all the way
                              We installed full synthetics last summer (Brunswick Pro Lane) and have not had any issues with sticking or excessive sliding. We do clean them with 99% alcohol, and clean the slide area with 99% alcohol with 1 oz. of Brunswick Approach Conditioner added to the gallon of alcohol 1x a week.
