ted again
  • ted again
    ted read the post on sanding first u say u use use paper on the g machine what grit do u open with and is it psa or do you spray the drum then apply the paper and also u use only two grits what do u close withu also use a sealer ive heard about but never used it can u tell me what it is .havent cut lanes in awhile just curious as to what has changed since ive done it.dont know if i mentioned it but have my own sanding equipment and learned form the master himself dan g spent 2 months probably 20 years ago why time flies doing our centers but since have changed to full synthetics in one center and heads only in another center but have 2 centers w wood any help would be appreciated
    Most of the time, we used 36 grit on the G. Occasionally, if there were 4-8 coats of finish, I'd use 30. It was paperback, never PSA. I'd spray a light coat on the drum while it was running after cleaning it, then spray a little on the first 20" of the paper to get it to hold on the drum as i put it on.
    I'd only use one grit on the G. with 36, we'd follow the G with 80 on a super sander. Starting at the end of the head and running it first back to the foul line, then just flat to the tailplank and back to the foul line. Only when i hit a bunch of nails with the G did i have to hit the head an extra time to minimize the grit scratches.
    After the 80 on the super, it's still 80 - 4 trips with 80 paper on the rotary, then 80 screen on a rotary. The sealer before the base coat was the ticket making it less important to completely close the grain so the base coat would stay on top of it.
