Lane oil
  • Lane oil
    Hello all,
    Anyone been using the Duramax Response lane oil from techline products ?
    If so, What surface?
    Also the Oxyshock cleaner ?
    Thanks
    Mike
    Just so you don't think we are ignoring your question...
    No.
      We put Response on for a very short time period, not nearly long enough to make an intelligent decision about it, but did observe the following: It is an oil that appears to hook which would make it compatible with low friction surfaces such as Pro Lane. It does let the ball recover from the outside without drying up the oil on the outside boards of the lane. Front end skid is good and the ball slows down well at the breakpoint. Would like to have had more time to test it.
      As far as Oxy Shock goes, I think it cleans as well as Defense C. They are my two favorites.
        I'm Using Oxyshock and love it. only 24oz to 2.5gal. If I remember correctly it also saves about a buck a gallon(mixed) over the product I was using previously.
        Idiocracy
