Lane Inspector said the panels were "loose"
  • Lane Inspector said the panels were "loose"
    We just had inspection and I got back a list with a good 2/3 of the house having been written down as "loose". When I spoke with the inspector he said that the panel seams had too large a gap that you could catch your finger nail on and we just needed to tighten the screws down. I know in the case of a crown or a depression you pull the panel and shim it to correct spec. I've never heard of this loose stuff before has anyone else? would that mean I have to pull the panels and make the seams level or what?
    The seams of the panels must be flush or drop down no more than 25/1000 of an inch according to USBC specs. The gap between the panels can be no more than 50/1000 of an inch at the time of installation. Hope this helps.
      He does not know what he is talking about - they need to have a drop off - he needs to get educated about inspections
      The edge of the next panel MUST be lower
        its 40/1000th drop panel to panel
          i was told when i helped install the lanes in Peoria to give a .007 - .015 of a drop
            As King stated...he does not know what he is doing.
            Print this manual and show him page 32 as it has the current specs for lane panel gaps and drop-offs.
            http://usbcongress.http.internapcdn....ecs-manual.pdf
              Thanks Steve. I stand corrected. It's 40/1000 inch drop. I had an old book that said 25/1000.
                That's a bit scarry that the lane inspector is clueless as to what the the panel drop is.
                  You cannot just add screws to a 'loose' spot. Between every row of screws, if a piece of shim paper has been added, the space between the screw rows can appear to be loose.
                  The weight of a ball won't depress this space, standing on it will. Adding a screw will pull it down to the underlayment or old lane, but unless it's shimmed the same as the 2 adjacent screws, it may be pulled out of spec.
                  The inspector should stand in the gutter, as specified for the past 60 years, to check the measurements of the lane surface.
                  If it is truely a panel joint that is loose, it should absolutely be fixed.
                  Also, the width of a joint filled with a sealer or adhesive cannot be acurately be measured, and can actually be assumed to be a '0' gap.
                    Try to remember that the local associations are largely made up of volunteers. These people have more experience with rolling the ball down the lane than anything else. The training they receive is only as good at the person doing the training! Our local association came to take some tapes a few weeks back. It was absolutely hilarious watching the lady teach a new guy how to assemble the device and spool the tape on it! It was like the blind leading the def! It's up to us, the folks who know what the specs are, to ensure that the association inspectors are taking proper measurements. Don't be too mean to these people. I'm sure they are trying as hard as they can.
                      Good post!
                        Mike...that is all well and good...as long as they realize they are NOT the experts here. I had one come in the other week to pull tapes. He went out on the lanes to pull the tapes...came back and told my GM that something was "dragging" on the outside of my lanes. My GM of course assumed he was correct and started letting me know I needed to fix it right away. I go out and look at the lanes and ask him to explain to me what he is seeing. He pointed out that the outside of the lanes was not shiny like the middle of the lane...so there must be something dragging in the oil...causing it to be dull. Nothing I said to him changed his mind...I let him pull his tapes and be on his way.
                        Really!?! If you are a volunteer...you should be happy when someone wants to teach you something new.
                          sounds like talking to a know-it-all bowler, oh wait, thats the volunteer!
