sidewalls and flat gutters
  • sidewalls and flat gutters
    What do you use, if anything to cover these high traffic areas? We put polyureathane on in Sept. 3 coats and it is peeling like sun burned skin. We have phonelic side bds. with wood gutters. Thanks.
    1. You do not coat the phenolic kickback - just the wood around it
    2. Are the flat gutters wood or high density plastic - only coat wood gutters
    If the coating is peeling off the wood - did you scuff it and clean the oil/dirt off with a cleaner?
      How old are your synth. lanes? most come now with new plastic flatgutters.( phoenelic does'nt need coating) In your slow time you can make your own, 1 inch bottoms and 3/4 inch sides with routered edges. ( then you're maintenance free)
        Have wood flats and phonelic panels nailed to wood kickbacks.
          Did you use Urethane from a bowling company or from a store? the stuff at Lowes and Home Depot is not good for that application, it will peel. Also as stated, proper preparation is a must.
          Cloth: ShamWow!
          Machine: Johnny 5
