looking orange peeling
hey guys i was wondering if anyone else has had a problem with a group of lanes that are dryer and look orange peeling all of our lanes were leveled this summer they were doing this before we leveled them all the other lanes look fine just 5 - 12 lanes 7-8 are the worse they are hooking out of the house by the 5th frame of the 1st game anyone have any ideals of how to fix this thanksTags: None
His profile says pro lane
Question - did they take up panels and re shim them?
If so did they use silicone sealer on the joints?
If they used silicone did the tape each side of the joint?
we didnt take the panels up we raised them up just enought to get the shim paper under them we didnt do any reshimming around the joints and this problem was like this before we even did the re shim it only looks orange peeling in the heads of the lanes the rest of the lane look good
Originally posted by bowlingman_21 View Postwe didnt take the panels up we raised them up just enought to get the shim paper under them we didnt do any reshimming around the joints and this problem was like this before we even did the re shim it only looks orange peeling in the heads of the lanes the rest of the lane look good
Did someone try a coating, or buffing with abrasive on the ones that are different color? Polychem had a finish and finish remover they tried for synthetic lanes, although the USBC says 'no finish on synthetic lanes'.
Did you get a friction sled with the lanes? Although primitive, it was accurate in the right hands to check the un-oiled surface..
Have you done a test clean to see if you're not leaving cleaner on the lanes. Oil applied over lanes cleaner has that look, nor does it adhere to the lanes surface, which would cause them to hook.Conditioner: Pantene Pro-V Brunette Expressions with Color Enhancer
Cloth: ShamWow!
Machine: Johnny 5
