oor pins. I have been using clorox and water but it seems abrasive to the deck finish. Sanded a house this summer that used NPS, what a mess those decks were. Almost totally black and nearly impossible to remove with anything I tried except the sander of course. What does work and what undesirable side effects are present?
Sliding pins
Sliding pins
Just wondering what everybody uses to minimize
oor pins. I have been using clorox and water but it seems abrasive to the deck finish. Sanded a house this summer that used NPS, what a mess those decks were. Almost totally black and nearly impossible to remove with anything I tried except the sander of course. What does work and what undesirable side effects are present?Tags: None
Tech of the Year 2009
- Nov 2000
- 19842
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Re: Sliding pins
Use the pin deck spray option with your Phoenix/S machine or Kustodian.
Just clear all the pins off the decks 1st.
Re: Sliding pins
We use Ledgends Pindeck Treatment. Works real well for about a week then our Kustodian strips it off. Polychem has some good stuff too but a bit on the pricey side. Of course if you have amflites you are going to be more suseptiable to oor than if MAX. Nature of design.
DeadwoodWell thats just like your opinion man...
Re: Sliding pins
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
