Zot Wizard Plus
  • Zot Wizard Plus
    Hi all,
    I'm trying to wire in the Zot Wizard Plus foul light to our Qubica Scoring, I'm not wiring into the lamps but using the autoscore wiring on the foul board, those wires are green, yellow, brown and orange, the qubica wires are red, black, white and green, Can someone tell me what wires go where for the scoring system to register a foul????
    Qubica wires are red and black for one side and white and green for the other. I think red and black are odd lane but I'm not sure right now. Qubica needs a DC voltage of about 3-20 volts to signal a foul. And polarity matters. If you get a good voltage and it doesn't work, swap wires. Your Zot units may or may not provide any voltage to the wires you want to use. Qubica has to hook to the bulbs on Brunswick foul units because their scoring wires only provide a switch closure to indicate a foul.
      If I recall Zot has 2 connection points on the board. 1 for AMF and 1 for Brunswick. As Badwrench stated, 1 is a low voltage connection and the other is just a relay closure.
      let me be myself
        I'm lazy so I'm just going to cut and paste from the user's manual. You can download this from ZOT for your particular unit but they all appear to be similar.
        First, you need to set the jumper for AMF.
        Then attach the wires. I'd verify the output voltages before actually attaching the wires though. You should get 12 VDC when set to AMF.,
        Hope this helps. Post back if it's still not clear. Better to ask than to damage something.
          Mr Badwrench, I hooked the wires to the bulb wires and still cant get the scoring to register a foul, so something must be wrong here, I even flip flopped the wires around and still no progress
