EnergyMizer
  • EnergyMizer
    Has or does anybody heard or have EnergyMizer. It hooks into your electect after your breaker box. Suppose to save 8 to 12% a month. Company name EMS (energy management system)
    http://www.dcsenergy.com/residential...ergy-miser.php
    http://www.bowltech.com/forums/showt...l=1#post376943
      The DCS Energy Miser, with the use of capacitors and new technology, reduces the electricity used by a building. It does this by increasing the building’s “Power Factor”– which improves its electrical energy efficiency.
      If the opening line is going to be that vague, I don't want it. "capacitors, and new technology"
      Your best bet is to retrofit your lighting. If you have incandescent lamps, switch them to compact fluorescent. If you have older T-12, 8ft. or 4ft. lamps, upgrade the lamps and ballasts to T-8 or T-5 lamps. The newer smaller lamps produce more lumins while operating at a much lower wattage.
