Soda Machine Lock
  • 8230chief
    OK sorry it took so long but our glass front water - bottle machine has the remote keyfob opener. I looked and guess what it has a 1/2" drill hole on top of the door. I guess you can reach in with a "J" hook and pull up on locking bar to open door. You may have to pull a clevis pin and disengage the motor actuation arm. Ours is a loner from the soda company, so I'm not sure who drilled it out. post a pic of your machine and if it's the same i'll send pics of where they drilled hole and what to grab on the inside.
    Later Chief
  • loadtoad
    I have been in contact with the Triteq folks and am waiting on a response. If there is a code, they should have one. Problem would be if it's a case of the lock motor bad or control board bad not sure what their actions are.
    Am just curious if there were anyone else that had ran into this problem. It's our machine, so the other alternative is to have a maintenance service call by someone to cut the door off or something i guess....but if it comes to that, I'd rather be the one destroying it.
  • Wookie8662
    If its not your machine, call the bottler who does own it.
    Sounds like a Triteq lock.
    Maybe try that website first?
  • mr.badwrench
    I think you'll need to find out who made the machine and contact them. Maybe if you unplug the machine for a certain amount of time and plug it back in it will reset the lock. Maybe pushing the numbers on the front in the proper sequence will open it but only the manufacturer would know that sequence.
  • loadtoad
    Electronic lock motor is not responding to open door. New/old FOB with or without extra battery pack bypass -- still no response.
    Either the lock CPU thing is kapoot or disco'd from last time someone was in there.....anyway, is there a way to get?
  • JoelJoanis
    What do you need to know?
  • loadtoad
    started a topic Soda Machine Lock
    Soda Machine Lock
    Anyone have experience opening vending machine doors controlled with key fob and no physical lock?
Broken Things!
Here ya go. This will get us started. This came off lane 40. Feel free to pile on!...
Help-broken Part
my crew was clearing a pin jam when the part fell on to the pin-deck. no enough experience to know where this is or what it's called. looking for help so we can order the part...
Qubica VDB Battery Replacement Part 2.
Greeting all.
I am sharing a link for a video, part 2, on how I replaced the battery in a Qubica VDB unit.
Thanks for looking.
Bolton454
Pin Damage
I have GSX pinsetters just over one year old. Just one of my machines is causing this damage to my pins. I have already adjusted the pin deflector boards to cover the bottom bolts...
Gold Crown Masking Unit
Here are some photos of a Brunswick Gold Crown single masking unit that I refurbished. I stripped off the old orange vinyl skin and used it to make a template for the new green...
