Part number needed
  • Part number needed
    Does anyone have the part number for this? The for the bottom wheel on the ball elevator. 20200822_135926.jpg20200822_135932.jpg20200822_135958.jpg
    https://brunswickbowling.com/uploads...ev-01-2019.pdf
    Here's a PDF you can download. Section M is powerlifts. You should find what you are looking for there.
      Great! I had that, but I hadn't looked down far enough. It's the Frameworx Ball Lift Bearing Housing (53-520685-001) if anyone else needs it. Thanks!
      Streamlane Mask Halo Lights
      Baddest Tool Chest In Town
      Adios, motor boater!
      Aluminum Repair and Welding
      http://aluminumrepair.com/...
      Hi, guys.
      check this jam...
      the ball stuck the table up
